Moxa’s EDS-G308 Series Ethernet Switch
By Design World Staff | August 13, 2008
The EDS-G308 series is equipped with 8 Gigabit Ethernet ports. Two of those ports can be designated for fiber optics, making it ideal for applications that demand high bandwidth.
Also, it provides an economical solution for your industrial Gigabit Ethernet connection, and the built-in relay warning function alerts system operators when power failures or port breaks occur. In addition, the EDS-G308 series includes 2 models: one with an operating temperature range of 0‚°C to 60‚°C, and the other one with an extended operating temperature range of -40‚°C to 75‚°C. These 2 models pass through a 100% burn-in test to ensure that they fulfill the special needs of industrial automation control. Lastly, it can be easily installed with DIN-Rail or panel mount options.
Key Features
–8 Gigabit Ethernet ports
–Fiber optic options for extending distance and electrical noise immunity
–Redundant dual 24 VDC power inputs
–Relay output warning for power failure and port break alarm
–Broadcast storm protection
— -40‚°C to 75‚°C operating temperature range (T models)
www.moxa.com
Filed Under: Ethernet — cables • hubs • switches
