MTS Expands Product Offering to Include Hall Effect Sensors
By Frank Tobe | March 11, 2014
MTS Systems Corporation (NASDAQ: MTSC), a global supplier of test systems and position sensors, announced that the Sensors Division has expanded its product line for mobile equipment to include the new Model HE hall effect linear position sensor.
“By offering the Model HE sensor along-side our line of MH-Series linear positioning sensors, we are able to provide equipment manufacturers with a wider range of sensor solutions,” explained Luka Korzeniowski, Technical Marketing Manager, MTS Sensors, Mobile Division. “This is particularly important to address applications with lower duty cycles and where pin to pin dimensions are critical.”
The new Model HE sensor features hall-effect, non-contact technology and is designed to cover stroke length measurement ranges from 100 to 400 mm. Multiple mechanical packages are available to allow installation into the hydraulic cylinder through both internal and external methods. IP69K sealing is also achievable with the use of MTS’s integrated M12 connector system on select models.
“With the addition of the Model HE sensor, MTS offers a larger product portfolio that allows our customers a greater choice for linear position sensing,” continued Korzeniowski. “The Model HE will provide customers an entry point to non-contact absolute position sensing with a clear upgrade path to our existing products. We are excited to add the Model HE sensor to our portfolio that offers the performance, reliability and optimized solutions that vehicle manufacturers need to remain competitive and promote ongoing technology advances to their customers.”
MTS Sensors
www.mtssensors.com
Mobile Hydraulic Tips
Tagged With: mtssensors
Mini machines draw ICUEE crowds
excavator1
Why do cylinders fail on an excavator?
AgfaPhoto
What makes a quality hydraulic component?
A look ahead with JARP Industries’ CEO, Kevin Kraft
