    • Subscribe!
Multi-axis motion sub-system boasts nanometer resolution
By Miles Budimir | January 19, 2021
The new X-417 multi-axis motion sub-system from PI (Physik Instrumente) boasts nanometer resolution, absolute encoders, fast configuration, delivery, and set-up. It’s suitable for a broad range of industrial precision motion applications, including precision automation, laser processing, test and inspection, medical manufacturing, and semiconductor testing.
Machine builders and system integrators can move faster and address new, higher precision applications with reduced risk and cost, due to the extensive testing that went into the X-417 pre-configured high-accuracy motion and automation systems, including EtherCat motion controllers and software. Its modular design enables application-specific configurations, scalability with optional accessories, and delivery by PI already aligned, tuned, and calibrated to designer’s specifications.
stages
The XY base system is made of two 3-phase motor-powered V-417 linear stages with travel ranges from 204 to 407 mm. Integrated absolute-measuring linear encoders provide better reliability, while eliminating the need to reference. A granite base plate is available for stability and can hold the G-901 EtherCat-based controller with ACS driver module.
The XYZ system includes an L-412 high-load linear stage mounted vertically, providing a 4 in. (102 mm) travel range. The Z-stage is equipped with a synchronous servo motor and a holding brake.
PI’s in-house engineered solutions have enabled engineers around the world to increase their productivity and technological advantage for five decades. With a large basis of proven motion technologies and methodologies, PI is in the position to quickly modify existing designs or provide a fully customized OEM solution to fit the exact requirements of applications from sensors and piezo transducers to microscope nano-focus units, fast photonics alignment systems to multi-axis automation sub-systems.
For more information, visit www.pi-usa.us/en.
Tagged With: PI, physikinstrumente
Elevator stages feature 0.03 micron resolution
igus offers custom toothed belt pulleys delivered in 48 hours
Enhancements to Thomson online ball screw configuration tool simplify selection and ordering
Beckhoff optimizes linear motion with machine learning solution that eliminates cogging
    • Subscribe!
