Multi-function Conductive Liquid Level Controllers
By Patrick Curran | January 19, 2011
Carlo Gavazzi launches a new generation of multi-function conductive liquid level controllers, with new and advanced features. The new CLD/P Series brings these new features together with a simpler than ever to use interface.
Carlo-Gavazzi-Conductive-Level-Controls
The multi-function controllers allow easy monitoring of two to four level points, with simple selection of functions, including filling, emptying, and new functions such as a tank-well option, which allows a single device to contol levels in an above ground tank and underground well, and prevent either from running dry. A master-slave option allows up to seven controllers to be directly connected to each other. A new single-point controller is added to the family, which includes a time delay function to allow for filling or emptying of a tank with a single level point.
All functions and adjustments of the CLD/P Series are made via rotary switches and potentiometers on the face of the unit – no dip switches or push buttons are used. LEDs on the controllers give clear indication of the power and relay output states. The controllers are in compact 17.5 or 35mm wide housings, with DIN-rail mount or eleven pin plug connection.
The CLD/P Series are UL, cRus and CSA approved, and designed to be in compliance with all relevant European and North American standards, and carry the CE mark. These are your assurances of a high quality, tested, and safe product.
Carlo Gavazzi
www.GavazziOnline.com
Filed Under: Test + measurement • test equipment
mti
MTI
moog
