Buffalo Grove, IL — Carlo Gavazzi announces the HAA08 (2-pole) and HAA14, (4-pole) multi-function Mini-Timers. These innovative 21.5 x 28mm timers feature a 24-240VAC/DC universal power supply and are mounted in a DIN-rail adaptable blade-type relay socket. They are easy to use and provide impressive load capability (up to 8 amps), and offer valuable space and cost savings.
The HAA08 and HAA14 offer a number of strategic advantages: Each of the two new models provides a solution for the majority of timing applications due to an extended time range of 100 milliseconds to 100 hours. Furthermore, they provide four functions: delay on operate, interval, symmetrical recycler “ON” first, and symmetrical recycler “OFF” first. The multi-function and universal features of these timers correlate to a significant inventory reduction. The process of selecting and setting the time range is also very easy. The HAA08 Series features 8Amp DPDT relay contacts, and the HAA14 Series features 5Amp 4PDT relay contacts. The primary specifications are as follows:
•Timing range from 0.1 seconds to 100 hours
•24 to 240 VAC/DC universal power supply
•Dipswitch selection of timing ranges (7 ranges)and of operating modes (4 functions)
•Knob adjustable fine tuning of the time setting
•Output: 8A DPDT (HAA08), 5A 4PDT (HAA14)
•21.5 x 28 mm miniature housing for blade socket (which can be mounted on DIN-rail)
The HAA Mini-Timers are UL recognized, CSA approved, and carry the CE and RoHS marks, your assurance of a high quality and safe product.
Carlo Gavazzi
www.GavazziOnline.com
Filed Under: Electronics • electrical, Test + measurement • test equipment
