The Extruded Flat Multi-Position (EFP) cylinder is a double-acting, single rod end cylinder that gives three positions. This unit simplifies machine changeovers and cuts down on costs.
The Extruded Flat Multi-Force (EFQ) cylinder is a double-acting, single end rod cylinder that doubles the resultant force on extension. It uses two pistons, eliminating the need for higher pressure systems or unique configurations. In addition, only one piston is pressurized on the return stroke.
Bimba Manufacturing
www.bimba.com
:: Design World ::
Filed Under: Motion control • motor controls, Pneumatic equipment + components
