AutomationDirect has added multifunction power meters to its line of electrical power products. Socomec DIRIS A power meters are easy to install and use power measurement devices with extended functionality for measuring electrical values in low voltage networks. Socomec power meters offer solutions for industry, infrastructure and data centers and provide reduced costs, reduced production losses, improved efficiency and enhanced performance.
With a large backlit screen, these power meters display key power system values, and direct access keys (four to six depending on the model) are used to access functions required for energy efficiency projects and electrical distribution monitoring.
DIN-rail-mountable (A10) and panel mount (A20) multifunction meter versions are available for measuring and displaying electrical values to be used for communication and output functions. All units are equipped with an integrated test function that can be used to detect incorrect wiring.
AutomationDirect
www.automationdirect.com/power-meters
Filed Under: Power supplies
