Multiple classified UL HazLoc cabinet coolers available
By Paul Heney | August 19, 2019
Hazardous Location Cabinet Cooler Systems are engineered and approved for use upon purged electrical enclosures found within classifed areas. The areas approved are Class I Div 1, Groups A, B, C and D — Class II Div 1 Groups E, F and G — and Class III. EXAIR’s HazLoc Cabinet Cooler Systems have been tested by UL and meet the stringent UL requirements for these areas.
Cabinet Cooler systems are a low cost and reliable way to cool purged electric control panels found within these environments. They utilize vortex tube technology to produce up to 5,600 Btu/Hr, with no moving parts, which additionally creates a low maintenance solution for cooling your HazLoc purged cabinets.
Hazardous Location Cabinet Cooler Systems are available in eight different cooling capacities from 1,000 Btu/Hr. to 5,600 Btu/Hr. This range of cooling allows for choosing the best fit for your cooling needs without placing additional demand upon your air compressor. Thermostatically controlled systems are recommended for the highest efficiency and include UL listed solenoids, also for hazardous environments.
Cabinet Cooler Systems protect electronics from heat, dirt and moisture and keep processes running. Components will fail, sensors will misread, controls can drift and displays become inaccurate. EXAIR HazLoc Cabinet Coolers can solve these problems and prevent lost productivity, shutdown and the expense of new components.
EXAIR Corp.
www.exair.com/58/hazloc.dir.htm
Filed Under: Cabinets • enclosures • control panels • DIN rail
Tagged With: exair
Paul Heney
