The MH1701 FORTELION high-output battery module is a candidate for industrial equipment requiring high output such as uninterruptible power supply (UPS) devices and instantaneous voltage drop compensators. This module is equipped with “FORTELION”, Murata’s proprietary lithium-ion secondary battery, which uses olivine-type lithium iron phosphate as the cathode material and combines long life with an exceptionally high level of safety.
In recent years, in keeping with the progress of IoT (the Internet of Things), the use of electronic control devices has grown and a more stable power supply is required than before at data centers and factories where precision equipment is manufactured. Accordingly, operators of such facilities have expanded their use of UPS and Ancillary Service in the interests of ensuring stable power supplies in the event of power outages. Conventionally, these devices are equipped with lead-acid batteries, but in view of issues such as short battery life, there is an increasing need to replace them with lithium-ion secondary batteries which feature longer battery life as well as space-saving and weight-saving capabilities.
In response to these needs, Murata has developed this high output battery module that features FORTELION’s sophisticated input-output characteristics, a high level of safety, and longer battery life.
Thanks to the stable crystalline structure made possible by employing olivine-type lithium iron phosphate as the cathode material, FORTELION is less vulnerable to breakage and less likely to catch fire, even if subjected to a large impact or significant pressure, and maintains a reliable battery performance even under intense workloads. FORTELION has received the Japanese safety standard for the emergency power systems “Emergency Power Supply Certification” and has its safety has been recognized in a test report based on the UL9540A international safety standard for storage battery fire risk in the US.
This product equipped with FORTELION is capable of undergoing 15,000 charge-discharge cycles. FORTELION provides a much longer expected operating life than lead-acid batteries that typically require replacement after around 500 cycles or regular lithium-ion secondary batteries that are capable of 2,000 to 3,000 cycles, thereby contributing to reducing LCC (life cycle cost).
The optimized secondary battery module structure and circuit design make possible continuous discharge from SOC 100% to 0% at 200 A.
Murata Electronics-Americas, 129 Flanders Rd. Westborough, MA 01581, www.murata.com
You may also like:
Filed Under: Power supplies
