AutomationDirect has added more choices to its offering of Murrplastik cable entry systems.
The addition of the KDL/D MONO series cable entry system provides the same benefits as the existing KDL/D series in a round frame form. This series allows a cable to be installed through an enclosure or other bulkhead surfaces, with the added benefit that pre-made, terminated cables can be installed without disassembling the connectors.
The newly added KDP/X cable entry system allows for a high density of non-terminated cables to be installed through a small area of an enclosure or other bulkhead surfaces.
The KDL/D MONO series is available in three frame sizes and starts at $36.00. The KDL/D series is available in four frame sizes and starts at $16.00. The KDP/X is available in one frame size, with bolt-in or snap-on mounting, and starts at $29.00.
The new Murrplastik cable entry systems are easily assembled and have a 2-year warranty.
AutomationDirect
www.automationdirect.com/cable-entry-system
