    • Subscribe!
N-TRON® Releases New Industrial Communication Products
By Patrick Curran | May 7, 2010
Mobile, AL – N-TRON Corporation introduces six new products designed for legacy serial communications in industrial environments. With this release, N-TRON has solved a growing problem for plant and factory managers—the integration of legacy mission-critical components with newer network technology. These cost-effective products bridge the gap between older serial and contemporary Ethernet protocols, allowing organizations to preserve their investment in programming and equipment while moving forward with advancing technology. Connectivity options for 10/100BaseTX and multimode fiber applications are available in each series.
N-TRON-ESERV-M12T
ESERV-11T/12T Series:
    * Easy web-based configuration software
    * Low latency, high throughput
    * Heatbeat connectivity
    * Built-in, switchable termination & bias
    * Compact industrial DIN rail enclosure
    * Extended operating temperate range -34°C to 80°C
    * Supports data rates up to 230.4 Kbps
    * 10-58 VDC input power range
    * Single or dual port serial connectivity
    * UL 508, CE approved
    * Starting at $199
ESERV-M12T Series:
    * Customizable Master/slave support
    * Real-time status messaging
    * Modbus messaging priority control
    * Dual port serial connectivity
    * Starting at $529
N-TRON  Corporation
www.n-tron.com
Filed Under: Networks • connectivity • fieldbuses
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
    • Subscribe!
