Mobile, AL – N-TRON Corporation introduce three new products designed for serial communications in industrial environments. The SER-485-IC, SER-485-FXC and SER-485-IR are designed to extend range, operate in temperatures ranging from -40°C to 80°C and provide 2000V 3-Way optical isolation.
Product Features
• -40°C to 80°C Operating temperature
• DIN-Rail Enclosure
• 2000V 3-Way optical isolation, input, output, and power
• 10-48VDC Input Power Range
• UL Class I, Div 2, CE Approved
The SER-485-IC converter optically isolates and converts RS-232 signals to RS-422 for increased range, or RS-485 for increased range and multi-drop capability.The SER-485-FXC converts RS-232, RS-422, or RS-485 to transmit over multimode fiber optic cable using ST style connectors. Fiber optic communication offers extended range and intrinsic optical isolation.
N-Tron SER-485-FXC N-Tron SER-485-IC N-Tron SER-485-IR
The SER-485-IR repeater provides optical isolation and extends range up to 4,000 feet. All 3 products utilize easy to wire removable terminal blocks for serial and power connections.
N-TRON Corp.
www.n-tron.com
Filed Under: Converters (electrical) AD + DA • transformers, CONNECTIVITY • fieldbuses • networks • gateways, Terminal blocks
