NBK offers multi-functional machined slotted springs
By Michelle Froese | August 10, 2020
Flexus products can be designed with suitable materials, such as aluminum alloys, stainless steels, engineering plastics, copper alloys, or others to match a customer’s requirements.
Advanced component manufacturer, NBK‘s Multi-functional Machined Slotted Springs (or “Flexus”) are multi-functional parts made of various materials (not only spring materials) with slits. Flexus products enable various spring properties such as compressing, tensioning, shearing, and bending. This is because the portion between the slits work as a spring.
The shape and dimensions of Flexus components are flexible. Due to an advanced cutting process, exact spring constants can be obtained for use in instruments where precision and reliability are required. For example, even polygonal shapes and cylinders can be manufactured.
The shape of the hub, which is the end portion for mounting, can also be manufactured according to the application. It’s also possible to reduce the number of parts required by making the spring and its attachments as an integral construction. NBK can make any spring function by arranging the slit shape, number, depth, and more. Furthermore, single or multiple start spiral slits are possible.
Typically, one needs to use some attachments (accessories), such as spring posts when installing a common spring coil but Flexus products can be designed with one piece construction including those parts. Doing so, will enable one to reduce the number of needed parts and enable one to save assembly procedure and reduce space.
Flexus products are fully customizable.
Learn more here.
Filed Under: Fastening + joining, Springs • wave springs • retaining rings • spring clips
Tagged With: nbk
