NBK’s XGHW-C flexible couplings
By Mike Santora | September 14, 2021
Flexible couplings with vibration absorption function added to high rigidity couplings. A structure with both high rigidity and vibration absorption. The individual dynamic vibration absorber*1 is separate from the inertial rotor and elastic body in order to achieve vibration absorption.
NBK-flexible-coupling-exploded
*1: The mechanism for suppressing resonant vibration phenomena is achieved by connecting the dynamic vibration absorber to the auxiliary inertial body via the elastic body.
  • Does not use resin elastic materials for the rotation transmission system from the motor shaft hub to the driven shaft hub, for high rigidity.
  • Achieves high positioning accuracy under high loads, in addition to high servomotor gain.
Applications
Actuator / Surface-mount machine / High precision XY stage / Index table
NBK
www.nbk1560.com/en-US/products/coupling
Filed Under: Coupling Tips
Tagged With: nbk
