Binder USA LP introduces the Series 670 NCC (Not Connected Closed) subminiature connectors, designed to offer high protection levels with a compact profile for applications where space is at a premium. These 5-pin subminiature connectors feature a bayonet closure and a cable bushing from 3.5 to 5.0mm. The new connectors meet a growing market demand for durable and reliable circular connectors in applications such as lighting and test and measurement instrumentation.
binder’s NCC connectors are ideal for applications that require frequent mating and de-mating as they offer continuous protection. When disconnected, a spring cover protects contacts against water, dirt, and penetration by foreign objects to IP54. When connected, the level of protection increases to IP67. The Series 670 NCC also offers high resistance to shock and vibration, as well as heat and cold with an operating temperature range from –13° to 185°F.
Summary of key features:
- > 1000 mating cycles
- Contacts: 5
- Rated current: 2 A
- Rated voltage 50 V
- Degree of protection: IP54 (unmated)/IP67 (mated)
- Contact plating: Au (gold)
- Termination: solder, dip solder
- Housings available in multiple colors for visual organization
Binder USA LP
www.binder-connector.us
Filed Under: Connector Tips
