Marvell (NASDAQ:MRVL), a world leader in storage, cloud infrastructure, Internet of Things (IoT), connectivity and multimedia semiconductor solutions, today announced its full-featured, Near Field Communication (NFC) 88NF100 Controller with Active Load Modulation (ALM) to support the smallest antenna sizes critical to mobile, IoT, wearable and automotive applications. Adhering to the NFC Controller Interface (NCI) Technical Specification version 1.1, the 88NF100 provides an extended operating range and is extremely energy-efficient to enable extended battery life for power critical applications.
The 88NF100’s ALM technology supports the smallest antenna sizes to enable OEMs to implement NFC capabilities into small form factor designs, making it ideal for mobile, IoT, wearable and automotive applications. The controller has extremely low power operation in polling mode to provide increased battery life for power critical applications and 3 Single Wire Protocol (SWP) interfaces to secure element (eSE) devices, ideal for secure payments. The patented two-pin antenna interface supports a maximum distance of two meters between the chip and antenna, supporting devices where the antenna must be located far away from the chip, such as with automotive and printer applications, in addition to designs with tight space constraints, including smartphones and wearable devices. Seamlessly integrating with Marvell’s Wi-Fi®, Bluetooth® and ZigBee® solutions, the 88NF100 is compliant with the NCI Technical Specification version 1.1 to leverage existing middleware and applications and supports GSMA, ISO and EMVCo industry standards.
Marvell will be showcasing its Host Memory Buffer and other cutting-edge storage solutions at CES 2016 in Marvell’s suite, Level 3, Murano No. 3304, at The Venetian. CES is being held in Las Vegas at the Las Vegas Convention and World Trade Center and the Venetian Hotel on Jan. 6–9, 2016.
Marvell
marvell.com
The post NCI 1.1-compliant 88NF100 NFC controller extends antenna range appeared first on Micro Controller Tips.
Filed Under: Automotive, Microcontroller Tips
