ND Industries’ Thermoloc processed parts save weight and costs
By Michelle Froese | September 8, 2020
Learn more about ND Industries’ Thermoloc pre-applied processes here.
ND Industries‘ line of Thermoloc­ pre-applied processes were developed as chemical alternatives to all metal locking features.
ND is a developer and manufacturer of pre-applied fastener thread locking, sealing, masking, and assembly products since 1955.
When compared, Thermoloc processed parts are more economical in terms of costs and weight. They prevent loosening due to the vibration of threaded assemblies.
Thermoloc processed parts are ideal for:
• Furnace Bolts
• Catalytic Converter
• Exhaust Manifold
• Turbochargers
• And more
The Thermoloc 450 — this process involves the application of a solvent-based threadlocker intended for use in high-temperature systems. Thermoloc 450 is compatible with either internal or external threads and the factory applied materials will remain inert on the fastener until assembly.
Once installed, the resin and hardener mix filling voids in the threads and curing to lock and seal the assembly.
The Thermoloc 1500 — the pocess applies custom threadlockers to fasteners intended for use in high-temperature systems where traditional organic thread lockers fail due to thermal oxidation.
The Thermoloc 1500 processing is compatible with either internal or external threads and the threadlockers applied will remain inert on the fastener until assembled and heat activated.
Tagged With: ndindustries
