NEMA 23 Dampers from Lin Engineering
By Design World Staff | August 13, 2008
Santa Clara, CA‚—Lin Engineering are pleased to introduce their new line of dampers. These dampers are durable, long lasting, and can easily be mounted onto standard NEMA 23 step motors.
As motors step, inertia makes the rotor oscillate about its new position. This natural back and forth movement might sometimes contribute to the erratic motion of motors. Adding a Lin damper to the step motor‚’s shaft translates into smaller oscillations and thus, smoother motion. This reduced step response time can ultimately result in much improved motor performance.
Installing Lin Engineering dampers is a simple process; all that’s needed is a M4 type screw. The durable and long lasting dampers are relatively maintenance free. Due to the sealing process that they undergo while being manufactured, accumulation of dust and debris becomes an afterthought.
For more information regarding Lin Engineering’s Damper series, including the option to see a video demo and performance graphs, please visit
linengineering.com/line/contents/stepmotors/Nema23_Damper.aspx.
Filed Under: Motion control • motor controls, Motors • stepper
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
Going small with 3D printing
