Nematron Expands M-Series Industrial Monitor Line
By Dave Miyares | March 2, 2010
Ann Arbor, MI – Nematron Corporation announces the launch of an additional model to the M-Series line of Industrial Monitors. This new 12.1” version called the M1200 addresses many space-constrained installations that the other M-Series Monitors could not. This additional version has all the same features and options of the other industrial monitors in the series. The M-Series now offers 12.1” SVGA (M1200), 15.0” XGA (M1500), 17.0” SXGA (M1700), and 19.0” SXGA (M1900) versions. All versions are standard with a clear Lexan window, built-in 100-240 VAC power supply, and NEMA 4/4x/12 powder coated aluminum front panels. 5-wire Analog Resistive Touchscreen, Stainless Steel front panel, or an integrated 24 VDC power supply are available options.
Nematron-M-Series-Industrial-Monitors
All versions in the M-Series line utilize bright, clear TFT LCDs and are powered by 100-240 AC integrated power supplies with optional 24 Volt DC. They all have NEMA 4/4x/12 powder coated aluminum front panels with optional Stainless Steel front panels. All units are European CE marked and are RoHS compliant. The M1200 will have UL/cUL approvals and will be approved for Class I Division 2 installations when mounted in a NEMA enclosure like the other members of this series.
Nematron
www.nematron.com
Filed Under: Displays • HMIs • operator interfaces • monitors, Industrial computers, ELECTRONICS • ELECTRICAL
