New 15.6” Widescreen Multi-Touch Flat Panel Monitor
By Frank Tobe | August 27, 2014
AdvantechAdvantech’s Industrial Automation Group is pleased to announce the launch of a new flat panel monitor specifically designed to meet the flexible demands of a wide range of applications and especially in areas which require continuous cleaning. The 15.6“ HD resolution (1366 x 768) wide screen 16:9 monitor provides 40% more screen area than 4:3 displays and can therefore display more information.
So that it can be cleaned and operated in a wide range of environments, the FPM-7151W is IP66 certified; making it dust-tight and protected against jets of water. Furthermore, with the addition of its multi-touch capabilities, through the use of an USB interface, ten touch points can be programmed to provide even greater control and viewing of the information shown.
As with all Advantech flat panel monitors, the FPM-7151W is easily mounted on panels or walls to provide a range of options for any type of industrial environment. Other features include RS-232 & USB dual touch interface, VGA & DVI-D dual video input port, and 0 to 50°C operating temperature.
For more information or to purchase any of our other of Advantech products, please contact Advantech directly or your regional Advantech authorized distributor.
Advantech
www.advantech.com/ea
Filed Under: TECHNOLOGIES + PRODUCTS, Industrial computers
Tagged With: advantech
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
New igus E4.1R rol e-chain reduces noise, vibration and saves electricity
