Nippon Pulse now sells the the PFL20 Linearstep — its smallest linear stepper motor yet. The PFL20 is a highly efficient, high thrust tin-can linear actuator with a 20-mm diameter and a bipolar winding.
PFL20 is RoHS-compliant, has a 30/60-mm effective stroke, and can reach 6 N of force at 200 pps. With 24 steps per revolution, the lead screw has a 1.2-mm thread pitch; the PFL20 also reaches 5-V rated voltage, resistance of 33 Ohms/phase and inductance of 12mH/phase. The datasheet with additional specifications can be found here.
The simple structure of Linearstep motors — just a threaded rotor hub and lead screw — helps to save space and reduce costs, due to fewer components needed compared to systems that convert rotary motion to linear. Linearstep motors are also easy to control and can be ordered with unipolar or bipolar windings and a variety of usable voltages. In addition to the 20-mm motor size, this motor is also available in 25mm (captive or non-captive option) and 35-mm diameter sizes.
Nippon Pulse’s tin-can linear actuators, including the Linearstep, are also available for customization; contact an application engineer to learn more about our customization capabilities.
Nippon Pulse America Inc. is an American subsidiary of Tokyo-based Nippon Pulse Motor Co., Ltd. Nippon Pulse is a global manufacturer and Tier 1 supplier of precision motion control products for original equipment manufacturers. We provide a wide array of motion control solutions to meet your needs, including industry-leading stepper motors, the innovative Linear Shaft Motor, controllers and drivers. For more information about Nippon Pulse’s quality products, visit nipponpulse.com or call 1-540-633-1677.
Filed Under: Linear Motion Tips, Motors • stepper
