New 3/8-in. Super Air Wipe dries, cools, cleans small diameters
By Paul Heney | June 21, 2018
exair blow offEXAIR’s new 3/8-in. Super Air Wipe produces a 360° airstream that can blow off, dry, clean or cool the material passing through it. The split design can be clamped around continuously moving material such as wire, cable, pipe, hose and extruded shapes.
The 3/8-in. Super Air Wipe ejects a small amount of compressed air through a thin slotted nozzle that pulls in high volumes of surrounding room air. The airflow uniformly ejects from the 360° of its inner diameter. Coupling brackets that hold each half of the 3/8-in. Super Air Wipe together can be latched together or removed quickly. Additional shims can be installed if more blowoff force is required. Air velocity can be varied with a pressure regulator and instant on/off control provides precision blowoff. Air consumption is 11.1 SCFM at 80 psig and the sound level is low at only 82 dBA.
Super Air Wipes are CE compliant and available from stock in aluminum and stainless steel in diameters from 3/8-in. (13mm) up to 4-in. (102mm). Large diameters up to 11-in. (279mm) are available from stock in aluminum. Applications include wiping wire; drying inks; cooling hot extruded shapes; and blowoff of water, plating, coatings and dust. Pricing starts at $286.
EXAIR Corp.
www.exair.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Flanges • supports • mounts • brackets
Tagged With: exair
Paul Heney
Paul J. Heney, the VP, Editorial Director for Design World magazine, has a BS in Engineering Science & Mechanics and minors in Technical Communications and Biomedical Engineering from Georgia Tech. He has written about fluid power, aerospace, robotics, medical, green engineering, and general manufacturing topics for nearly 25 years. He has won numerous regional and national awards for his writing from the American Society of Business Publication Editors.
Siemens launches Siemens Xcelerator – an open digital business platform to accelerate digital transformation
Xometry introduces tools to accelerate the creation of locally resilient supply chains
PROSTEP expands cooperation with Siemens Digital Industries Software
engineering in plain sight
Book review: A plain explanation of every day engineering
