Fort Myers, FL – Crystek’s CVCO55CXT-5685-5780 VCO (Voltage Controlled Oscillator) operates from 5685 MHz to 5780 MHz with a control voltage range of 0.3V~4.7V. This VCO features a typical phase noise of -102 dBc/Hz @ 10 KHz offset and has excellent linearity. Output power is typically +0 dBm.
Engineered and manufactured in the USA, the model CVCO55CXT-5685-5780 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 5V, with a typ. current consumption of 25 mA. Pulling and Pushing are minimized to 0.5 MHz and 1.5 MHz/V, respectively. Second harmonic suppression is -30 dBc typical.
The CVCO55CXT-5685-5780 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
For pricing details, contact Crystek Corporation.
For more information visit www.crystek.com.
