Microsemi Corporation (Aliso Viejo, CA) announced its new ZL30252 and ZL30253 any-to-any frequency clock multiplier and jitter attenuator integrated circuits (ICs). These devices target new applications with tough jitter budgets and tight board real estate restrictions. The new devices provide communication equipment customers with a timing solution that meets industry-leading jitter performance imposed by new 100Gbps PHY devices. Key features include:
- Any-to-any frequency conversion with 0 ppm error (inputs: 1kHz-1.25GHz, outputs: 1Hz-1GHz).
- A digital PLL with programmable bandwidth from 14Hz to 500Hz.
- Input clock monitoring and automatic or manual input switching.
- Three universal clock inputs that connect to any signal format at any voltage and up to three differential outputs or six CMOS outputs.
- A configurable output signal format and voltage for direct interface without additional components.
For more information, visit www.microsemi.com.
