JTM Products, a manufacturer of quality industrial lubricants, introduces a breakthrough multi-use product intended for shop or factory applications: the Barracuda Triple Action Lubricant. Its proprietary formulation delivers superior “bolt-busting” rust penetrant performance on seized fasteners while providing excellent cleaning and corrosion inhibitor protection for metal surfaces.
Learn more about Barracuda’s benefits and capabilities here.
Barracuda Triple Action Lubricant penetrates rust and breaks-free seized fasteners better than the leading consumer penetrant and keeps fasteners from quickly re-seizing. The product’s unique chemistry works quickly, attracting it to the metal to break loose even the most corroded bolts.
This means less time wasted trying to loosen tough fasteners, freeing time to fix what needs fixing.
Independent laboratory testing proves the new generation rust inhibitor in Barracuda Triple Action Lubricant delivers the best protection in even the harshest environments. A special water displacement property wicks moisture away from metal surfaces while providing a thin imperceptible protection film.
Applications
- Loosens frozen pipe joints, nuts, bolts, screws, clamps, etc.
- Lubricates hinges, slide mechanisms, bearings, gauges, etc.
- Stamps and blanks, light to medium gauge aluminum or steel coil/sheetstock
- Rustproofs machine tables, bushings, machine/hand tools, gun barrels, farm implements and any area susceptible to corrosion or high humidity
- Displaces moisture from motors, pumps, wires, and switches
- Cleans off rust and light oils from machine beds, chucks, ways, gears, threaded holes and internal machine parts
JTM Products
https://koolrite.com
