Applimotion is now offering interior permanent magnet (IPM) versions of their ULT, UTH, UTS, and UTO frameless motor kits, extending capabilities to new applications.
The IPM frameless motor kits cover sizes from 44 mm to 533 mm diameter and torque outputs that exceed 1,000 Nm. The IPM designs provide a combination of higher continuous torque output, smooth operation, higher inductance, and minimized magnet content for cost effective performance to suit the application. The motors can be optimized for 12 to 600 V applications by modifying the winding.
IPM motors are finding their way into many special purpose applications in robotics, warehouse automation, remotely controlled/unmanned vehicles and traction drives, which require high torque at low speeds plus a wide speed range. IPMs have a unique ability to provide wide constant power output range when controlled correctly without the need for special magnet wraps and retaining bands for high speed operation.
Filed Under: Warehouse automation, Motion Control Tips
