New Compression Spring Line Offers Very High Spring Rates Without the Bulk
By Frank Tobe | February 6, 2014
LeeSpringLee Spring’s newest Stock Spring solution is a unique line of low index, High Pressure Compression Springs. In the past, customers found high spring rates only in the largest stock compression spring sizes or in custom designs. The Lee Spring engineering team that introduced BANTAM™ Mini and Lite Pressure™ Compression Springs is back with yet another application driven stock product line. They carefully designed an offering of 144 slender parts packed with high load capacities, rated to pressures of 300, 400, and 500 psi. High Pressure Series Compression Springs in 17-7PH Stainless Steel are passivated, shot peened, and preset, providing a balance of corrosion resistance, high strength, and toughness.
This line is ideal for anyone in need of firm yet not rigid springs designed with slender profiles, suitable for small spaces and common applications such as:
• Ball plungers
• Quick change tools
• Switches
• Safety relief valves
• Vise clamps … and many more!
Lee Spring
www.leespring.com
Filed Under: Springs • wave springs • retaining rings • spring clips
Tagged With: leespring
Comments
  1. yehia says
    October 28, 2019 at
    applications of high pressure compression springs thank you very much
  2. Anonymous says
    October 28, 2019 at
    applied to atmospheric pressure -added to – to lift water up and harness that action
