Product Depot Inc., a company that develops innovative products to improve jobsite and consumer use, has announced the launch of the Sub-Tite Cable Clamp.
The Sub-Tite Cable Clamp is designed for holding wires to a well pipe while keeping the wiring centered in the casing along the entire drop pipe. It has a first and second clamping member, configured for interlocking around the outer surface of the drop pipe and help prevent wire damage.
The Sub-Tite Cable Clamp is a user-friendly cord management and fastener tool that enables professionals in the well industry to quickly and efficiently secure wires along the drop pipe.
Safely and properly securing wires to drop pipes is a routine part of well installation and maintenance. However, the traditional tools for attaching the wires — such as electrical tape, cable ties, and hook and loop products — typically make the process more time-consuming and fail to hold reliably.
Insecure attachment can cause pump wiring breakage and damage, increasing costs and the need for more frequent maintenance.
To solve this problem, John Bardo, co-founder of Product Depot and veteran inventor of time-saving construction tools, created the Sub-Tite Cable Clamp. In collaboration with well industry experts, Bardo specially designed the tool to hold wires of varying sizes when attached to the drop pipe.
“Based on the many years I spent in the hardwood flooring industry, I understand the critical importance of having the best tools for the job,” said Bardo. “With this tool, I’m proud to be able to help make well maintenance faster, safer, and more efficient.”
Thanks to its easy-to-use, dual-locking mechanism, the clamp can be installed securely along the length of the drop pipe four times more quickly than tape. Made from food-safe plastic, the clamp can be safely used in drinking water.
“I have been in the pump industry for 35 years and have installed and serviced hundreds of well pumps every year and have thought for some time there has to be a better way to secure the wire to the pipe,” said Rick Spann, owner of Service Pump Co. in Auburn, CA. “I believe this clamp by Product Depot Inc. will change the way we secure our submersible wire cable to our drop pipe in the domestic well pump industry.”
Filed Under: Clamps • locks • latches
