Crees silicon-carbide (SiC) technology continues to enable smaller, lighter, more efficient and lower-cost power systems with a new all-SiC 300A, 1.2kV half-bridge module. Packaged in industry-standard 62mm housing, the new module reduces energy loss due to switching by more than five times compared to the equivalent silicon solution. This best-in-class efficiency enables for the first time all-SiC high power converters rated up to the megawatt level, extending Crees leadership in SiC chip technology into high current power modules.
“The drop-in feature of Crees new all-SiC power module allows us to achieve 99 percent efficiency while reducing the power module count by a factor of 2.5 in our existing HF induction heating systems, said John K. Langelid, R&D manager, EFD Induction. These benefits are greatly valued as a reduced cost of ownership by our end customers.”
The new all-SiC 62mm half-bridge modules game-changing switching efficiency and performance allow designers to reduce the amount of magnetic and cooling elements, delivering double the power density and a lower system cost while also reducing end user cost of ownership. Offering a simplified two-level topology that is feasible at higher frequencies, the new module can also eliminate the need to invest in multi-level silicon-based solutions.
The latest Cree® SiC power module is available with multiple gate driver options and is pin compatible to standard 62mm half-bridge modules, including IGBT modules rated at 450A or more. This allows designers to quickly and easily evaluate the modules unparalleled capabilities.
“The new 62mm half-bridge power module is yet another example of Crees commitment to the commercialization of SiC-based power electronics,” said Cengiz Balkas, general manager and vice president, Cree Power and RF. “Utilizing our success in large-area SiC power devices, we have extended the benefits of SiC power modules to the 100kW to 1MW power range for applications such as induction heating, central solar inverters and active front-end motor drives. These new power modules are introduced at a breakthrough price-performance point that unlocks immediate cost savings in these applications.”
Cree
www.cree.com
Filed Under: Power Electronic Tips
