EXAIR‚’s new compressed air powered E-Vac vacuum generators are the low cost way to create a vacuum for pick and place, clamping, lifting, chucking, alignment and surface mounting.
E-Vac compressed air powered vacuum pumps provide instantaneous response and are most commonly used for pick and place operations. These single stage vacuum pumps are a low cost venturi available in a variety of sizes and flows along with a selection of suction cups suitable for a wide range of applications.
The E-Vac in-line vacuums have been engineered for high efficiency to minimize air consumption. Mechanical vacuum generators frequently experience fluctuations in vacuum. EXAIR‚’s in-line, single stage design eliminates the fluctuations, providing consistent, steady vacuum. Dust and other contaminants can easily pass through the vacuum generator without clogging it up (no filter required on the vacuum). E-Vac is maintenance free and has no moving parts to wear out.
Filed Under: Pneumatic equipment + components, Pumps
