    • Subscribe!
New Edge Roller Technology (ERT 250) Conveyor from Dorner
By Mike Santora | June 9, 2020
Dorner ERT 250 ConveyorNeed a pallet handling conveyor capable of zoning and packing for accumulation and automation assembly applications?
As implied by its name, the ERT 250 uses rollers to move pallet conveyors smoothly with no friction (a byproduct often seen in belt-driven platforms). The conveyor’s open design eliminates concerns of small parts or screws dropping into rollers and causing conveyor damage or jamming. The ERT 250 is suitable for applications calling for pallet or tray handling; no- and low-back pressure accumulation; medium to heavy load assembly automation; and Cleanroom applications such as medical product or device manufacturing, assembly, packaging, and others.
The rollers are driven by a patent-pending, energy-efficient linear gearbox that gives customers added flexibility with motor positioning and zoning. This allows for zone and slip roller operation. Simply removing a lower gear creates independent zones. The non-contact zone control provides simplified traffic control that eliminates pallet stops and costly pneumatic valves. Conversely, slip rollers can be used for full length runs with conventional pneumatic pallet stops. The rollers are easily accessible and can quickly be replaced without affecting the remaining portion of the conveyor.
Technical specifications of the new ERT 250 include:
· Widths 120 to 960 mm wide
· 38 mm diameter rollers on 50 mm centers
· Loads up to 250 pounds per pallet or tray
· Loads up to 15 pounds per roller
· 150 mm minimum long tray
· Speeds up to 30 m (100-ft) per minute
· Aluminum frame with two T-slots
· Energy-efficient brushless DC gearmotors and controllers; motor controllers use Ethernet IP for easy communication
· Reversible
· Automation modules
o Navigate 90° and 180° corners
o Lift and transfer
o Lift and locate
o 90° pusher
· Three transportation modes
o Non-contact accumulation
o No- or low-back pressure slip roller accumulation
o General transport
Dorner
www.dornerconveyors.com
Filed Under: Conveyors
Tagged With: dorner
Custom pneumatic conveyors for unique applications
Dorner-Conveyor
iDrive2 Mag-Drive Motor saves energy while boosting sanitary attributes
New wheels for ergonomic & AGV applications
    • Subscribe!
