    • On the Floor
New Emerson pneumatic valves provide greater automation flexibility, optimized flow
By Heather Hall | July 18, 2024
Emerson has launched its AVENTICSTM Series XV pneumatic valves. These valves are designed with interoperability in mind to provide machine builders across multiple industries and factory automation applications with a flexible and cost-effective valve platform. The new valves are ideal for machine builders and end users who operate globally, with universal threads and other features that support regional standards and global availability.
The new AVENTICSTM XV valve series features multiple interoperable valve sizes and higher flow rates in a compact design.
Series XV valves provide higher flow rates in a compact valve package that enables more efficient and flexible pneumatic system performance for factory automation, automotive and tire, and food and packaging applications. This helps manufacturers boost productivity and allows them to offer products customized for specific markets and customer preferences.
“In all industries, manufacturers need high-performance technology that gives them the agility and flexibility to stay ahead of rapidly changing market demands,” said Wolf Gerecke, director of product marketing for Emerson’s machine automation business. “The new AVENTICS Series XV pneumatic valves deliver that performance with optimized flow, a wide range of valves, and an extensive portfolio of accessories.”
Series XV valves include the XV03, which provides flow volumes of up to 350 liters per minute in normal conditions (NL/min), and the XV05, which is scheduled for release in October 2024 and provides up to 880 NL/min.
All valves in the Series XV line use proven AVENTICS core technology and include metal threads, parallel wiring, aluminum base plates and compact dimensions to make it easier to integrate into production system designs.
Series XV valves use consistent interfaces and have wide connectivity from single wiring over parallel connections such as D-SUB connectors. They also support leading fieldbus protocols, including PROFINET, Ethernet/IP, EtherCAT, Powerlink, Modbus TCP, IO-Link, and AS-I, to simplify integration into machine control networks.
Series XV valves are also easy to commission. The AVENTICS online configurator supports system layout and provides useful information, while easy-to-understand system documentation in the design phase helps speed up machine development.
www.emerson.com
Filed Under: Pneumatic equipment + components, Valves
Tagged With: emerson
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
