New family of Non-isolated SMT DC-DC Converters from TDK-Lambda
By Design World Staff | March 5, 2012
TDK-Lambda Americas has announced their new family of non-isolated SMT DC-DC converters that comply with the latest 2nd Generation DOSA standards for Point-of-Load (PoL) Converters.
TDK-Lambda-DOSA-PoL-Converters
Key advantages of the new DOSA-2 models include high power densities; no external tuning components (plug & play), low profiles, high efficiencies, and Edge Plated Castella-tion (EPC) pads for easy SMT solder joint inspections. These converters are ideal for harsh telecom/broadcast mast-mounted applications, as well as industrial, test & meas-urement, and medical equipment.
TDK-Lambda’s DOSA-2 product line is comprised of four series with output current/power ratings as follows, iCF: 3A/16.5W, iCG: 6A/33W, iBF: 12A/66W and the iAF: 20A/110W. All of these operate with a wide input voltage range of 4.5V to 14V and feature adjustable output voltages from 0.7V to 5.5V with conversion efficiencies up to 97%. These miniature 2nd Generation DOSA modules range in size from 12.2 x 12.2 x 4.45 mm (less than 0.5 square inch) to 33 x 13.46 x 7.75 mm. Optional LGA (Land Grid Array) SMT solder pads are available instead of the standard EPC pads.
Featuring fully-optimized control loops, all modules provide excellent transient response without external loop-tuning components (as is the case with some competitive products). Remote On/Off, Remote Sense and Power Good Signal are standard. Units can operate in ambient temperatures from -40°C up to +115°C and include a 3-year warranty.
These converters operate at a constant switching frequency of 600 kHz, which provides a low noise profile and facilitates easy EMI filtering. All models are safety certified to UL/CSA60950-1 and VDE CB scheme per IEC/EN60950-1.
TDK-Lambda Americas
http://us.tdk-lambda.com/lp/products/dosa2-series.htm
Filed Under: Converters (electrical) AD + DA • transformers, Filters (electrical) EMI • COTS • noise filters • shielding, ELECTRONICS • ELECTRICAL
