    • Subscribe!
New Gen4 four outlet power supply for static eliminators
By Kelsey Zebrowski | October 7, 2020
EXAIR’s new Gen4 Four Outlet Selectable Voltage Power Supply allows you to choose input voltages of 115VAC or 230VAC. Four 5kV stainless steel output connectors can energize four static eliminators at the same time. Applications using up to four Gen4 Super Ion Air Knives, Ion Air Guns, Ion Air Cannons, Ionizing Bars or any other EXAIR Gen4 static eliminator product can be connected to one power supply. Like all EXAIR Gen4 products, these four outlet power supplies are UL component recognized, CE and RoHS compliant.
They also feature an electromagnetically shielded modular power supply cable which eases routing and connections. An integrated fuse on the primary protects against voltage spikes. The lighted power switch indicates operation and is field replaceable. The Gen4 Four Outlet Power Supply is housed in a durable metal enclosure (6″ L x 4.0″ W x 4.4″ H) that is ideal for rugged, industrial environments. Gen4 static eliminators having a bayonet-style connector can be inserted into the power supply where the electrical connection is made deep inside to prevent a shock hazard.
Gen4 static eliminator products using this power supply are all shockless and have armored high voltage cables which resist abrasion and cuts. The four outlet power supply price is $535. For more information, visit this deep link exair.com.
You may also like:
  • Safety Air Guns designed for high performance and safe operation
  • Wear resistant pneumatic conveyor provides high throughput
  • EXAIR’s Air Atomizing Spray Nozzles atomize fluids in variety of…
  • EasySwitch Vac simplifies the process of vacuuming wet and dry…
  • Hazardous Location Cabinet Cooler Systems operate under toughest industrial conditions
Filed Under: Power supplies
Tagged With: exair
Wago-pro2-power-supplies
WAGO Pro2 Power Supplies and DC-to-DC converters from AutomationDirect
Traco Power launches new AC/DC power supplies
ECO 2 power supplies balance size, efficiency with tool-free installation
AutomationDirect-Power-Supply
RHINO power supplies with integrated UPS and Power Boost Technology
    • Subscribe!
