New hydraulic gear flow meters can take the pressure
By Mike Santora | February 2, 2016
Webtec-press-release-imageWebtec, the hydraulic measurement and control company, based in Milwaukee, WI has announced the launch of a brand new range of high-pressure, precision gear flow meters rated up to 40 US gpm (150 lpm) for use on applications as diverse as hydraulic component leak testing, wind turbine lubrication monitoring and offshore
diagnostic fault-finding.
In an industry first the new GF series is designed specifically for the hydraulic and lubrication market, not the process industry, so all products are designed and calibrated for use on oils, or phosphate-esters or water-glycols. Webtec recognized that positive displacement meters, like the new GF series, are often used in such a wide range of industries that the engineer tasked with specifying them is often baffled by the number of, often irrelevant, options.
Since hydraulic circuits are often prone to regular pressure spikes, Webtec has ensured the new GF gear flow meters are rated up to 6000 psi (420 bar) maximum operating pressure, and also have a safety factor of over three, unlike many process meters.
Product selection is made easy as all meters come complete with the transducer pre-fitted, linearized and pre-programmed, fully traceable certified test results and the option of suitable connecting cables. The GF series uses an all stainless steel construction and comprises three sizes covering the range 0.03 to 40 US gpm (0.1 to 150 lpm) and offers accuracy of better than 0.5% of the indicated reading with both frequency (Pulse) and mA outputs as standard.
Webtec
www.webtec.com
Mobile Hydraulic Tips
Filed Under: Cables + cable management, Hydraulic equipment + components
Tagged With: webtec
igus advances the circular economy with the first e-chain made entirely of recycled material
igus becomes world’s first manufacturer to receive UL approval for halogen-free TPE cables
igus expands E4.1 e-chain modular system for long travels
zuken
Harness-building software simplifies quoting process, automates harness documentation
