New igus E4.1R rol e-chain reduces noise, vibration and saves electricity
By Heather Hall | May 23, 2022
igus, manufacturer of motion plastics and moving cable management systems, has introduced the E4.1R rol e-chain. The new rolling energy chain system dramatically reduces noise and vibration.
Integrated roller links have been added to the standard modular system of the E4.1 energy chain series. This makes it especially easy for users to change over from gliding to rolling energy chain systems. The rollers in the E4.1R reduce drive power by up to 37%, minimizing energy requirements.
The E4.1R is available with 56 mm and 80 mm inner height. Add several widths and radii, and you have a total of over 900 variants for individual applications. The roller chain links are also fully compatible with the entire E4.1 series modular system, so indoor linear robots in the machine tool industry can still be retrofitted.
Reduce electricity costs in times of sharply rising energy prices
Wholesale electricity prices are skyrocketing, and for many industrial companies, the cost of electricity poses a significant challenge in staying competitive. And saving electricity is critical. This applies to entire production lines, individual machines or components such as energy chains that carry cables and hoses for energy, data and hydraulics in industrial systems.
As a rule, the upper run of an e-chain system slides on the lower run. Usually, this is not a problem over short distances in terms of energy because the igus high-performance plastics enable low-friction operation. However, with longer travel distances of several hundred meters and high loads of up to 100 kg/m, the coefficients of friction increase and thus also the energy consumption.
E4.1R: Rolling instead of gliding saves energy
For 20 years, igus has been offering energy chains for long distances, in which the upper run rolls over the lower run, reducing friction and wear.
“Due to rising prices and energy costs, many industrial companies have become interested in cost-saving measures. They ask themselves how operating costs can be cut with the components in use, such as energy chains – especially on long travels with high additional loads,” said Jörg Ottersbach, head of the e-chains Business Unit at igus. “Our answer is that we also offer a version of our E4.1, the E4.1R, with integrated rollers. This series is one of our best-selling energy chains and a universal solution for 90% of gliding applications.”
For more information, visit  igus.com/info/cable-carriers
You may also like:
  • The additive technology link with digital twins
  • The electrical connection specialists take steps to become a system…
  • SPEE3D showcases first cold spray metal 3d printed wheel at…
  • How can a machine recognize hand gestures?
  • Desktop Metal will show an historic collection of 300+ 3D…
  • An important recognition for additive manufacturing
Filed Under: Belts + chains
Tagged With: igus, igusinc, igus inc.
PM6021-1
igus introduces self-lubricating toothed belt axis
Gates expands thermoplastic polyurethane line-up with best-in-class parabolic pitch belts
New flour power belts for milling machines
Wafer-handling machine maximizes performance with specially clamping belt-pulley and bushing assembly
