EXAIR’s new 1/2 NPT internal mix atomizing spray nozzles atomize fluids in a range of spray patterns and liquid volumes for a variety of uses. They combine liquid and compressed air inside of the air cap to produce the finest mist of atomized liquid that can be easily adjusted to meet the needs of your application. These 1/2 NPT spray nozzles provide high liquid flows up to 303 GPH and are available with multiple spray patterns including narrow angle round, wide angle round and flat fan.
With EXAIR’s atomizing nozzles, you can coat, cool, treat and paint a variety of products using compressed air and liquids with a viscosity of up to 300 centipoise. Used with water, atomizing nozzles are an efficient way to evenly cool hot items in your automated process. They are also commonly used with light oils, rust inhibitors, chemicals, paints and dyes.
The stainless steel construction of these atomizing nozzles adds to their durability and corrosion resistance. EXAIR atomizing nozzles are available with 1/4 and 1/2 NPT connections and in a variety of sizes and shapes to meet your needs. All models are adjustable, come with our 5 year Built to Last Warranty and are CE compliant. 1/2 NPT internal mix spray nozzle prices start at $580.00.
EXAIR
www.exair.com
Filed Under: Lights • signal lamps • indicators
