New Magnetic Rotary Sensors from Novotechnik
By Patrick Curran | January 13, 2012
Novotechnik U.S. introduces the R-Series of magnetic rotary angle sensors. These sensors use the orientation of a magnetic pick up to determine angle so that there is no mechanical wear.
Novotechnik-R-Series-magnetic-rotary-sensors
An embedded microprocessor, contained within the R-Series sensors, converts the magnetic orientation to an analog output that is repeatable to within 0.03% or 0.1° of measurement range– depending on model. These rotary position sensors can be programmed and reprogrammed for your application’s angle, CW/CCW direction and single or redundant output can be selected.
R-Series have a measurement range up to 360° and have 12- or 14-bit resolution, depending on model. R-Series models include RSC28, RSC48, RSC66 and RFA4000 sensors
Novotechnik U.S., Inc.
www.novotechnik.com/rs
Filed Under: Factory automation, Sensors (position + other), Test + measurement • test equipment
Tagged With: Novotechnik
Solid-state relay characteristics and applications
