Cicoil, the inventor of the world’s first IDC Ribbon Cable in 1956, is pleased to announce the introduction of its new ultra-flexible micro IDC ribbon cable, available September 4. Unlike stiff PVC and Teflon versions, the space-saving, 0.025 in.-pitch Cicoil version has been designed for tight routing applications that require dependable signal density, reduced cable width and exposure to harsh environments, mechanical stress and excessive temperatures (–65° to 260°C).
Cicoil’s patented extrusion process allows individually encased, finely stranded bare copper wires to be placed in a very small flat profile, precisely controlling the spacing of each component and the overall cable shape. Approximately, half the size of standard 28 AWG IDC ribbon cables, the new 30 AWG Flexx-Sil rubber jacketed cables are available with up to 64 conductors. Fully terminated assemblies are offered in 3, 6, and 12 ft lengths. In addition, the cables are completely compatible with any Insulation Displacement Connectors (IDC).
Check out this YouTube video which shows how to quickly and easily install an IDC connector to the Micro IDC cable:
The micro IDC ribbon cables are rated for 3000 Vdc and are resistant to water, alcohol, hydrogen peroxide, humidity, UV light, radiation, flames, aging, autoclave, ozone, sunlight, fungus, vibration and many chemicals. When a non-adhering jacket surface is desired, Cicoil offers its SlideRite and GlideRite low friction coating options by request.
Cicoil’s halogen-free micro IDC ribbon cable is UL and CSA Recognized, CE Conforming, RoHS & REACH Compliant, Class One Clean Room Rated and are cured continuously, with no debris or material contamination in an automated, climate controlled environment. In addition, the non-particulate generating cables exceed the outgassing requirements of ASTM E595 and are also excellent for use in vacuum environments.
Cicoil
www.cicoil.com
