    • On the Floor
New Motion Series Plus Silicone Cables
By Design World Staff | June 24, 2008
Valencia, CA — CICOIL announces the immediate availability of new Motion Series PLUS (MS+) flat power/signal cables for high-performance motion control applications. This new series integrates 6 power conductors and 20 signal wires in a compact flat cable measuring just 0.80″ x 0.2″. Motion Series Plus cables feature ultra-high-flex shielded wires and Cicoil’s exclusive ‘glass-clear’ silicone encapsulation for unsurpassed flexibility, durability and environmental resistance.
Two options are available on Motion Series Plus cables. The first is integrated Teflon‚® tubing for transmission of fluids or gases. The second is Cicoil’s new patent pending StripMount‚â„¢ integrated mounting aid. StripMount‚â„¢ is reinforced strip embedded in the cable that allows for quick and easy cable mounting, eliminating the need for bulky, expensive cable management systems. StripMount‚â„¢ allows fasteners to be safely inserted through the cable for secure attachment to virtually any surface.
Cicoil’s Motion Series Plus cable is available in a single axis design that may be ganged for 1, 2 or 3 axes of servo motion. Their silicone encapsulation provides a solid, one-piece construction that creates a highly durable cable package. The cable will not deform, break or wear during a lifetime of more than 10 million cycles, even under high flex conditions. Cicoil’s exclusive silicone process also delivers advantages in extreme environments, including temperature ranging from -65‚°C to +260‚°C. They are also impervious to water, steam and chemicals. Their solid construction makes them uniquely well suited for vacuum or clean rooms environments.
www.cicoil.com
Filed Under: Cables + cable management, Motion control • motor controls
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
