Regal Beloit Corporation’s new Browning TorqTitan notched belt uses innovative elastomers, optimized cord arrangements and notch profiles to make it the most power-dense and energy-efficient V-belt that Regal has ever produced. The high-horsepower belt outperforms similarly sized belts in a wide range of applications, while being 30% stronger. No re-tensioning is needed, and it requires neither maintenance nor downtime.
“The TorqTitan notched belt is the industry’s first bandless zero-maintenance V-belt,” said Jesse Dupuis, director of marketing — HVAC industry group at Regal. “The belt’s innovative minimal-stretch cord technology and a proprietary cord treatment process keep it from suffering from severe tension decay in the first hours after installation. So, no run-in period or any re-tensioning is required. This is especially convenient in difficult-to-reach belt drives. No re-tensioning means no machine or production downtime and helps reduce downtime costs for maintenance and plant engineers.”
The specially engineered shape in the notch design reduces bending stresses for improved flexibility, increased heat dissipation and better performance on small pulley diameters. This improved flexibility helps increase belt life and lowers energy consumption while also improving drive performance.
The TorqTitan belt, with newly formulated EPDM rubber material, resists hardening to avoid cracking in temperatures up to 260 °F, making it suitable for hot-air HVAC applications or other high-temperature environments. Similarly, the belt maintains exceptional performance in extreme cold conditions as low as -58 °F.
For more information on the Browning TorqTitan notched belt, visit www.regalbeloit.com/torqtitan.
