New P8 line of micro stepper actuators from Actuonix
By Lisa Eitel | June 9, 2021
The P8 line of micro stepper actuators from Actuonix is a new ultra-compact design. This unique new line of micro actuators enables a new generation of motion‐enabled product designs, with capabilities that have never before been combined in a device of this size. Stepper actuators are a superior alternative to designing your own push/pull mechanisms. Featuring a long-life stepper motor, the P8 is an ideal choice for projects where mounting space is tight and long-life is a priority.
The P8 is available in 10mm, 25mm, 75mm and 100mm stroke length options to fit a wide variety of applications. Two gearing ratios are also available, 49:1 and 165:1 to match your force and speed requirements. A maximum duty cycle of 100% makes the P8 the right choice for applications where the actuator will run consistently.
The P8 with the Tic T825 driver board is recommended and available on the website. However, the stepper actuators can be driven by most 4-wire stepper drive boards.
For more information, visit www.actuonix.com.
Filed Under: Actuators
Tagged With: actuonix
Lisa Eitel
