New panel mount pumps with DriveSure technology
By Andrew Zistler | March 17, 2016
pumpWatson-Marlow Fluid Technology Group is introducing a new range of panel-mount OEM pumps featuring DriveSure brushless DC gear motors with fully integrated speed controllers. Designed for use by medical device specialists serving the surgical ablation market, the RXMD DriveSure range provides a single source solution for OEMs requiring pumps, motors, gearboxes and drives.
The RXMD DriveSure is able to deliver very low flows at high back-pressure up to 87 pounds per square inch (6 bar) through catheters or needles in cooling applications. It also features an innovative mechanism that offers improved flow accuracy. Furthermore, a tube holder ensures the tube locates in the right position every time the safety lid is closed, providing rapid, trouble-free tube loading. This minimizes the risk of human errors and safeguards the process.
In surgical ablation applications, the pumps can be used to deliver cooling fluid, which in turn produces a more effective treatment and prevents scarring. The addition of DriveSure is seen as a huge advantage as it means OEM engineers can bring products to market faster and with less engineering cost by eliminating the time, design uncertainty, and risks associated with the separate specification of pump, motor, gearbox and drive. DriveSure is highly adaptable and directly accepts market-standard analog control signals.
A further benefit is that engineers can eliminate the inherent risks of buying various system components from different manufacturers, with the safety net of a single, comprehensive two-year warranty for the drive (the pumphead comes with a one-year warranty). Importantly, this includes a performance guarantee for the complete pump and full integration support.
Ultimately, RXMD DriveSure represents a ‘fit and forget’ solution, while the use of Watson-Marlow’s own gearbox provides the customer with excellent torque and silent running.
RXMD DriveSure is available in several variants able to match customer flow, pressure and rotation direction requirements.
Watson-Marlow
watson-marlow.com
Filed Under: Pumps
Tagged With: watsonmarlow
KNF’s Diaphragm Liquid Pump FP 70 provides a smooth flow and high efficiency solution
KNF’s new smooth flow, high efficiency diaphragm liquid pump FP 70
spartan scientific high-pressure solenoid pump
High-pressure solenoid pump offers fluid control for rigorous needs
KNF launches four new vacuum/compressor pumps for industrial applications
