Mill-Max is expanding its line of wire termination products by introducing six new pins and receptacles, three mated pairs, which facilitate the wire attachment process. Each features a solder cup for easy and efficient soldering and is precision-machined to provide consistent and reliable interconnections.
These mated pairs of pins and receptacles are ideal for use in cable and wire harness applications and, as they all incorporate press-fit features on the barrels, are perfect for assembling into connector configurations per specification. Each pair is designed to support either 20, 16 or 14 AWG wires. The receptacles are a two piece construction with a precision-machined outer shell and stamped beryllium copper internal contact. Like all Mill-Max receptacles, they are capable of multiple insertion and extraction cycles and are rated to carry current matching that of the wire sizes the solder cups are designed to accept. The pins and receptacle shells are plated pure tin, matte finish and ready to accept solder. The receptacle inner contact is gold- plated and 30 micro-in., for durability and conductivity. Other plating options are available upon request.
Mill-Max
mill-max.com
The post New pins and receptacles provide reliable interconnections appeared first on Connector Tips.
Filed Under: Connector Tips
