New patent-pending FRRV valves are dual-function fixed, pressure compensated, priority flow controls with built-in adjustable relief on the priority leg, and an integral damping chamber in the priority section to improve stability. They are well-suited for applications that require re-combining the priority flow to the bypass flow. Having two valve functions in a single cartridge can reduce space requirements and cost in a hydraulic system.The larger size is rated for maximum inlet flows of 20 gpm/76 lpm, fixed priority flows to 12 gpm/45 lpm, and system pressures to 4000 psi/276 bar.
HydraForce, Inc. Lincolnshire, IL 60069 Toll Free: 1-800-682-6875 Phone: 847-793-2300 Fax: 847-793-0086 Web: www.hydraforce.com
.: Design World :.
Filed Under: Hydraulic equipment + components, FLUID POWER
