    • Subscribe!
New proportional thumbwheels with friction-hold option
By Andrew Zistler | February 18, 2016
asdadsfThe new patented HR Series Friction-hold allows for ultra-precise movement while allowing the user to hold the selection in a set position.
The HR series’ uses proven non-contacting Hall effect sensor technology, independent from the friction mechanism, providing a smooth and precise linear voltage output that does not degrade over time.
The HR series thumbwheels now come in two versions: one with 11 detents along the travel (1 at center and 5 on each side) and another with a center detent, smooth movement on each side and providing a feel of friction hold without detents.
Historically, speed control was achieved through the use of a potentiometer or rotary switch, which are generally large and bulky. Hall effect sensor technology improves the user experience with optimized ergonomics, efficiency and a longer lifespan. Sealed up to IP68, the HR series with friction hold is ideal in applications that include panel mount and joystick
integration as well as agricultural machinery, material handling equipment and off-road vehicles.
APEM
apem.com
Filed Under: Switches
Tagged With: apem
omron-d2gw
Heilind Electronics adds Omron D2GW Sealed Ultra Subminiature Switch to its portfolio
PX AND PA Series foot switches
The fundamentals of electromechanical on/off switches
HoverTap Lift from NZ Technologies takes elevator call buttons to new highs
    • Subscribe!
