AutomationDirect has added ProSense SC6 series high-density pulse isolators and frequency input signal conditioners which handle a variety of discrete, pulse, and frequency signals. Pulse isolator models provide a simple and reliable way to split a single input into two independent outputs, while frequency input models convert a wide range of frequencies into usable analog or relay signals for downstream devices.
The SC6 series features an ultra-narrow design for high-density mounting, intuitive DIP switch configuration, and full isolation between input, output, and power. Units are powered via terminal inputs or an in-rail power bus. Their rugged construction ensures reliable operation across wide temperature ranges and high-vibration environments.
For more information, visit automationdirect.com/signal_conditioners.
