ATLANTA Drive Systems, Inc. will showcase their new Rack & Pinion Drives and Linear Actuators at Booth E-4829 during IMTS 2016 at McCormick Place in Chicago, September 12 – 17, 2016.
Further expanding their hardened & ground rack range, ATLANTA has added DIN 7 and 8 quality levels to provide more competitive price points to meet customer’s accuracy needs. The new StrongLine DIN 5 hardened & ground gear racks utilizes an innovative carburized case-hardening process to increase the strength of the rack, including the tooth flanks and root, which maximizes its power density, stiffness and performance.
The new TR ISO 9409-1 flanged pinions have compact designs to reduce the amount of drive torque required and allow for a smaller reducer to be used. These pinions make it possible to achieve very highly dynamic axis drives with high precision & repeatability.
Also available is a new range of ATLANTA High-Performance Linear Actuators, offering precise linear positioning and high dynamic performance by means of a servo-worm reducer and precision ballscrew spindle. These linear actuators are available in four sizes with rotating and non-rotating spindle versions, as well as lifting cylinder design and can be used with 100% duty cycles.
www.atlantadrives.com
