    • Subscribe!
New robust encoder for vector motor control from Leine & Linde
By Miles Budimir | June 21, 2016
Leine & Linde’s new MRI 2850 bearing-less encoder is designed for high horsepower electric motor applications using vector control. It’s of particular use as a motion feedback solution in applications such as large rotating machinery typically found in the construction, pulp & paper, oil & gas, wind and marine industries.
The MRI 2850 is a hardy encoder, offering stable outputs and robust line drivers with a unique code-wheel securing mechanism. The lightweight aluminum enclosure reduces the effort for installation and is coated to prevent corrosion.
Designed for mounting on a NEMA standard 8.5-in. C-Face, the sensor technology provides extremely compliant tolerances. One or two independent read-heads can be provided, each with any resolution between 1 and 16,383 PPR. The IP67-protected read-heads include power and status LEDs so proper mounting and operation can be visually determined at any time.
The robust electronics include advanced sensing technology to assure stable speed measurement without ripple or ghost pulses, and without the need for special shielding. In addition, the tough output drivers can support signal frequencies up to 100 kHz at 30 V over 350 m cable lengths.
The magnetic code-wheel on the MRI 2850 supports shaft sizes from 1 to 4 in. without the need for a stub shaft. Magnet material is permanently covered with a stainless steel shield, eliminating damage from mechanical contact.
For more information, visit http://www.leinelinde.com.
encoder
Motion Control Tips
Tagged With: leinelinde
New servo and motion bundles simplify machine integration
POSITAL extends product finder portal to include kit encoders
Kit encoders now included in product finder portal from POSITAL
    • Subscribe!
