New seals and materials launched for aerospace industry
By Paul Heney | December 17, 2019
Freudenberg Sealing Technologies introduced several new material and sealing innovations at the 2019 International Paris Air Show, products designed to help aerospace customers address ever increasing safety and performance requirements in the industry.
The company showcased a new high-temperature, fireproof material; a new Omegat OMS-CS cap seal; and new ethylene propylene diene monomer (EPDM) and a fluoroelastomer (FKM) developmental materials.
“Our aerospace customers strive continuously to be faster, safer and more efficient, which in turn requires us to innovate to help them reach those goals — a challenge we enthusiastically embrace,” said Vinay Nilkanth, VP, Global Mobility Sector, Freudenberg Sealing Technologies. “The launch of several new products aimed at improved performance underscores Freudenberg’s commitment to being a global leader and development partner to the industry.”
The company’s new proprietary fireproof sealing fabric is made to withstand to the extremes. Tested on standard aerospace bulb seals and passing AC20-135 fireproof requirements, the fabric acts as a barrier, providing up to 15 minutes for neces¬sary corrective action. The fabric performs as well as other industry standard solutions but is much more cost effective.
For use in dynamic, reciprocating applications where low friction is required, the new Omegat OMS-CS cap seal is a two-piece rod seal set consisting of an engineered polytetrafluoroethylene (PTFE) ring and an O-ring energizer. The seal offers low breakaway and running friction and is chemically compatible with aerospace fluids and greases. It also provides excellent wear and extrusion characteristics and has angled blow-by notches and lubrication grooves.
The new developmental EPDM LM426288 material is for use in low pressure static sealing to -77° C and has excellent resistance to, and swell behavior in, AS1241 phosphate ester hydraulic fluids. The material offers high temperature compression set resistance and short-term resistance to 150° C for high temperature hydraulic systems such as hydraulic braking.
The FKM LM426776 developmental material for use in low pressure static sealing to -67° C shows excellent resistance to several aerospace media, including jet turbine and gearbox lubricants, high and low aromatic content jet fuels, and fire-resistant hydrocarbon hydraulic fluids. The material offers short-term high temperature resistance to 270° C and long-term compression set resistance at 200° C.
www.fst.com
Filed Under: Aerospace + defense, Appliance engineering + home automation
Tagged With: freudenbergsealingtechnologies
Paul Heney
